'57 850 Fuel Line
Jim
03-22-2002 10:14:14
I'm looking for a diagram or photo to show the routing of the fuel line from the tank to the sediment bowl. Any and all help will be appreciated.
George H
03-23-2002 07:28:15
 Re: '57 850 Fuel Line in reply to Jim, 03-22-2002 10:14:14
Can't help with a diagram, a verbal description may or may not be useful: Leaving the shutoff valve, the line bends left, then down through the manifold runners between the manifold and the engine block. I don't get along well with steel tubing and flare nuts, so you might consider buying a new line from New Holland. Take the tractor serial number for this part. NCA9282D is between 1/55 and 12/57, and 310918 is between is between 1/58 and 12/60 before serial number 126525. Don't have any idea what the difference is, but probably has to do with the sediment bowl/carburetor.
AB
03-24-2002 05:49:27
 Re: Re: '57 850 Fuel Line in reply to George H, 03-23-2002 07:28:15
It's line size as well 7/16 for the later
