Order Ford 4000 Parts Online
Ford 4000
Belinda
03-27-2002 11:13:51
I have a 3 cyl. diesel serial #B258471. I need a manual. Dont know the year. Can someone help?
Cody N.E.Tex
03-30-2002 17:43:23
 Re: ford 4000 in reply to Belinda, 03-27-2002 11:13:51
Some were made in Belgium
TimK
03-28-2002 14:22:14
Belinda: All of the responses are applicable only if your tractor is not English made. I think it is, and imported thru Canada like many were. The "B" you noticed stands for Basildon England. I also saw several tractors when I was looking for my 2000, and those with the "B" prefix did not have the usual codes referred to in all the manuals and links provided to you in the other responses. They did have several serial numbers on the boss on the bell housing but none made sense at least in terms of what is supposed to be there. I researched some serial number years at the NH dealer (Who had them in a big book) but I found out that the English serial numbers overlapped some years (so why have a serial number right !). By the way, all of the 3 cyl. engines were made in Basildon, commonly referred to as "BDE" engines, regardless of whether or not the rest of the tractor was US. If you find a link somewhere that breaks down Englinsh serial numbers, please post it, since this question seems to come up quite often on this Board. My $.02.
RickB.@
03-27-2002 17:22:38
Serial #'s with B prefixes are not able to be used to date tractors. Find the unit code near the serial # you found, either on the data plate under the hood or on the clutch housing. Will be something like 9G15B. That will tell you the day and shift the tractor was built.
Belinda Ashmore
03-28-2002 18:27:03
 Re: Re: ford 4000 in reply to RickB.@, 03-27-2002 17:22:38
I found 5G16 next to the serial # is this it? If it is can you tell me what model it is? Can you tell me where to check the hydralic fluid?
jsp
03-30-2002 17:19:49
 Re: Re: Re: ford 4000 in reply to Belinda Ashmore, 03-28-2002 18:27:03
Please note that the following information applies to the 1965 thru 1974 Ford 4000 tractor.
I think 5G16 may be a partial production code and can be translated as follows:
5 = Year 1965
G = Month July
16 = 16th day of the month
There should also be a letter "A", "B" or "C" at the end of this code, e.g. 5G16A. This letter is the production shift code. A = Midnight, B = Day and C = Evening.
On the right side of the tractor just behind the starter there is flat surface on the transmission housing. There will be two threaded holes just below this flat surface. On this flat surface there are three numbers inscribed into the metal. The top number is the tractor model number, second is the production code, and the third is the serial number.
I have saw these numbers on many of the "C" prefixed tractors. I have no personal experience with the "B" prefixed tractors, but I believe they should follow the same rules as the "C" prefixed ones.
Go look on the tractor again. Try to clean this area to find the codes. It takes time, but it can be done.
Please note that this information also exist under the hood panel above the battery on a sticker. Try looking there first. Many of the tractors have lost this sticker or have had them painted over.
Belinda
04-03-2002 09:56:11
 Re: Re: Re: Re: ford 4000 in reply to jsp, 03-30-2002 17:19:49
I talked to a man in Ireland he told me to check under the hood, I found these numbers. D1C14C,
B923155, unit number 3G29B. Thanks
Bill N
03-27-2002 14:50:45
Scroll farther down ,see "Ford 4000 serial number" from Mark Gundrum & look at the various answers; that should at least narrow down the year
Ev Hanson
03-27-2002 13:42:23
Try Link this tells how to get the year from the production date code
Papa Bee
03-27-2002 12:14:41
Check with your local Tractor Supply, Tractor Dealer, or start clicking. I've found my best info. on the net. I also own a 3 cylinder diesel. Love it.
Belinda
03-27-2002 12:24:13
 Re: Re: ford 4000 in reply to Papa Bee, 03-27-2002 12:14:41
I have checked with several local dealers, the B at the start of the serial number confuses them. Any idea what the B stands for? Also how do I find out what year model it is?
Belinda
03-27-2002 14:58:22
 Re: Re: Re: ford 4000 in reply to Belinda, 03-27-2002 12:24:13
thanks Dave, can you tell me where to find the date code and model number.
Dave
03-27-2002 13:34:46
Oh yeah, you cannot tell the year by the serial number on an english made tractor. They did not go in order. You will have three sets of numbers Model#, Date Code, Serial#. You will need the date code to tell what year.
Dave
03-27-2002 13:32:11
The B mean it is an english made and C means US made. All you need to knwo for a manual is Ford 4000. The manual will cover many modals.
