Order Ford 3000 Parts Online
3000 CAV injector pump
Jason
03-30-2002 10:18:58
Having trouble, I have good flow to the bleed screw but none to the fuel lines??
Bern
03-30-2002 19:43:52
 Re: 3000 CAV injector pump in reply to Jason, 03-30-2002 10:18:58
Quite possibly the metering valve inside the pump is stuck in the "off" position due to moisture contamination. If this in fact the case, at the very least, the top cover of the pump will need to come off so this valve can be removed and freed up. Don't try this without directions.
Also, make sure that the kill cable lever on the pump is all the way forward. More than once have I seen it slip in the bracket, and cause the fuel to be shut off when the owner thought it was on.
