Order Ford 3000 Parts Online
3000 oil filter leaking
jd
04-19-2002 13:50:28
My 3000 diesel has the cartridge type oil filter. When I bought the tractor a couple of years ago there was no leakage between the oil filter and the block. Every time I change the filter I do not get a good seal between the block and the oil filter housing. When I first crank the tractor and raise the RPM, the leak is severe, but then stops and just seeps.
Can anyone give me some suggestions on what I might be doing wrong? Thanks.
RickB.
04-19-2002 17:10:44
 Re: 3000 oil filter leaking in reply to jd, 04-19-2002 13:50:28
In all likelyhood the canister is slightly bent. Do yourself a big favor and go to a New Holland dealer and buy a spin on conversion kit to use a more modern spin on filter. NAPA also can get them.
