12 Volt Conversion
Jay B.
04-24-2002 10:05:20
HELP!
I am trying to upgrade my NAA from 6V generator to 12V alternator. I have the alternator mounted, and looking great, but I am not sure how to wire it up. It is a 1 wire alternator. Do I put the 1 wire to the starter solenoid where the battery goes, and just remove the regulator. Then what do I do with the key switch. Oh Lordy, I'm confused. I can't seem to find DETAILED instructions or pictures anywhere on the net. THANKS!
Craig MO
04-24-2002 18:49:59
 Re: 12 Volt Conversion in reply to Jay B., 04-24-2002 10:05:20
On one wire alt. conversions that I have done take wire going to armature and put on big post on alt. Tape off the wire going to the field post on the generator. Go back to the regulator and put the GEN or ARM wire which ever its labeled on the regulator and put it on the same post marked BAT. If your alt. has a diode to keep from backfeeding which it should this is all you have to do. You will need to rev up tractor before it starts charging as it is now internaly excited this is normal
Rod MI
04-24-2002 10:19:19
Jay this is what you are looking for good luck Rod MI
