3 point Hydro's
Alex F.
05-03-2002 09:01:20
the three point on my dad's 9N lifts high enough to "dump" the small trailer we got. But mine, a 631 industerial type - barley gets a blade off the ground.
Is there any thing i can do to raise 'em higher?
Thanks
Alex
Craig MO
05-03-2002 20:23:57
 Re: 3 point Hydro's in reply to Alex F., 05-03-2002 09:01:20
If blade will stay up with engine shut off then you do not have oil bypassing. I would then take lift off and check my adjustments. Maybe the first thing to look at is to see wether your draft lever is in draft or position. It should be in the position position.
