What is serial number x01 mean?
BobN
05-05-2002 03:38:20
I am trying to figure out the x01 serial number type as it relates to 621, 821, 841 etc.
Are the x01 serial number referencing relate to the 621, 821, 841 tractors?
When did the "x21" tractors appear?
thank you.
Jim.UT
05-05-2002 21:45:37
 Re: What is serial number x01 mean? in reply to BobN, 05-05-2002 03:38:20
In 1958 (production starting in late '57) Ford upgraded their "Hundred" series tractors (600,700,800,900) to what we here like to call the "x01" series'. The 600 series became the 601, 700 became 701, etc. Within each of these series were several models. A 601 could be a 621, 631, 641, 651, 661, or starting in '59, a 671 or 681. Each model number calls out a different set of equipment, transmission, pto configuation, etc. Here's a site to help straighten it all out. Be sure to click on the serial number button after reading the history pages.
I have read conflicting info about the x21 tractors. One source says it had a 4 speed trans while other sources say it had a 5 speed. What does yours have?
Tony Jacobs
05-07-2002 21:08:56
 Re: Re: What is serial number x01 mean? in reply to Jim.UT, 05-05-2002 21:45:37
Hi Jim, While it is not set in stone most all 620's and 820's were five speed tractors, and most all 621's and 821's were four speed tractors , one reason was after the 01 series came out with more power the four speed was the choice for durability , that's why you will never see a factory 1801 series tractor with a five speed and a very limited amount of 01 series light industrials with a five speed and probably never with a backhoe from the factory . Thanks Tony
bOBn
05-06-2002 01:44:12
621 has a 4 speed with a Sherman Step up, and power steering. Plus a PTO and yellow colored 3PTH (What should I pay for it?
is xx1 the same as x01?
05-05-2002 16:53:57
I'm trying to figure things out. WHend did the x21 series come out and what should I pay for a 621 with pto and a lift installed later? BobN
