3 point lift question
Gordon
05-09-2002 17:33:16
Have a friend that has a Jubilee, that will raise the lift arms when it's cold, but after it warms up, it will not lift at all. I would appreciate any thoughts on this matter amy of you might have. Thanks in advance for your responses.
TomG
05-10-2002 02:51:07
 Re: 3 point lift question in reply to Gordon, 05-09-2002 17:33:16
On tractors that have suction tubes, another cause of the symptoms is a blocked or broken tube. Clogged hydraulic filters are common causes of obstructions. Hydraulics start off working OK and then deteriorate with use. The problem is characterized by hot frothy oil. I suppose something similar could happen on most any tractor. Such conditions can damage hydraulic pumps.
Craig MO
05-09-2002 20:07:11
As the tractor warms up the oil gets thinner thus leaking by eaiser. Raise three point arms up with a load on them like a blade and shut the engine off. If the blade drops rather quickly your oing on lift cylinder are bad. If the load stays up you could have bad oring on the stand pipe or your pump needs rebuilt.
