Order Ford 600 Parts Online
4600 Oil
Rhyds
05-15-2002 11:56:11
What oils should be used in a 1980 4600 engine, gearbox, axle, diff etc? What brands are recomended?
Roy B
05-16-2002 07:22:33
 Re: 4600 Oil in reply to Rhyds, 05-15-2002 11:56:11
Rhyds, Pretty hard to top Ford/NH 134 hydraulic fluid for the tranny and rear end sump. Try Shell Rotella T 15w40 in the engine. Roy
Craig MO
05-15-2002 19:44:45
Ford 134 hydraulic oil or any good grade hydraulic oil.
Texadian
05-17-2002 10:13:17
 Re: Re: 4600 Oil in reply to Craig MO, 05-15-2002 19:44:45
The transmission,hydraulic, rear axle oil needs
hydraulic additives (antifoam, etc), needs EP (extreme pressure) for crown and pinion, moly- type additives for oil bath brakes; the amount of wet brake additive seems to be the tricky one; it determines the wetness or slipperyness of the oil. If the oil is too "dry" (not enough moly) the brakes will chatter, too wet and they won't grab. One way of being sure you get the right oil is to use what the manufacturer recommends: New Holland 134.
