Order Ford 4000 Parts Online
1964 ford 4000
don from nc
05-16-2002 03:41:36
I recently bought this tractor and it was allready converted over to 12 volts & delco alternator & instead of points it has electronic module under the dist well it smoked and the tractor quit running and I want to put points back in it. can you buy the plate that the points sit on because the plate the module sits on is riveted to it any help would be greatly appreaciated thanks' Don
rwh
05-16-2002 18:42:32
 Re: 1964 ford 4000 in reply to don from nc, 05-16-2002 03:41:36
My '62 4000 did a similar thing and it turned out to be the plug wires. Get a continuity tester (TSC had them for $1.99 recently) and check your wires. Don't do what I did and replace points, condenser, coil, etc. before checking them.
don from nc
05-16-2002 18:53:30
 Re: Re: 1964 ford 4000 in reply to rwh, 05-16-2002 18:42:32
I have got the points & condenser in it but my coil says it is resistorless so before i try it i need to put a ballast or resistor in line to keep from burning the points up I will give this a few months then spend the money & put eletronic module back in it when I work all the bugs out of it THANK YOU GUYS FOR ALL YOUR ASSISTANCE DON FROM NC
Mike
05-16-2002 06:53:51
Hi Don,
I've got a 63 4000 with the stock 6 volt setup, as I haven't had a lick of trouble with it and the engine usually starts before making two revolutions, I think I'll leave well enough alone. You might be able to pick up a new distrubitor (I don't think you'll find anyone willing to remove just the plate from a good used distrubitor)from the supplier listed on the left side of this page.
You might find someone who converted their tractor to 12 volt and get a breaker plate from them, maybe Tommy D. could furnish one. Good luck
Mike
Tommy D.
05-16-2002 04:46:37
Don,
I have a 1964 4000 (Model 41202) with a 12v conversion and the Genessee Electronic Ignition you have. It was the best thing I ever did when I added the Electronic Ignition. I would encourage you to look at other things that might cause your problems and keep the "point-less" ignition.
These tractors are notorious for carb problems. Even plugs & wires could cause this.
Just my opinion,
Tommy D.
don from nc
05-19-2002 06:29:50
 Re: Re: 1964 ford 4000 in reply to Tommy D., 05-16-2002 04:46:37
ALL FIXED it was the coil that burned up the electronic module it had a internal short which was giving the module 40,000 volts. so I went to the auto parts store and pinked one up for $16 with resistor built in runs the best since I bought it a month ago. thanks guys, DON
