Order Ford 4000 Parts Online
4000 Temp Sending Unit
Mike S
05-21-2002 15:02:18
I'm trying to make my guages work in my 4000, and cannot locate the temperature sending unit. The manual hasn't been a bit of help. Since there were no wires of any kind behind the guage cluster when I bought the tractor, I couldn't retrace the old wires. Can anyone point me in the right direction?? I know it must be near the front of the block, but I don't see it.....
Thanks,
MS
TomWisc
05-29-2002 05:11:02
 Re: 4000 Temp Sending Unit in reply to Mike S, 05-21-2002 15:02:18
On my 69' 3000 3 cyl dsl, the temp sender is in the front at the top just next to the thermostat housing. It is in a spot where it can be completely covered in grease and grime, so you might need to do some cleaning to uncover it. The oil pressure sender is on the side just below and in front of the filter.
RickB.
05-22-2002 14:32:20
From the scant info you provided, I am guessing you have a 3cylinder 4000. The temp sender is threaded into the front of the head just to the right of the thermostat housing. 4 cylinder 4000's use a mechanical gauge threaded into the right rear corner of the head.
Grant
05-21-2002 22:07:08
Right rear of head next to fuel tank mount on '63
David Tiefenbrunn
05-21-2002 19:14:36
Check the right rear of the head - on a '64 Diesel anyway.
Scott
05-21-2002 15:15:17
Check the front of the head.
