Order Ford 801 Parts Online
1801 Ford Industrial power steering
Doug Ellis
05-22-2002 18:14:05
I need help with my 1801 ford power steerng .
It has a full power steering system that uses cables. the lower cable has been repaired to many times and is now to short. Does any one know how to fix this ????? ????
Any new ideas
Roland Jackson
05-22-2002 21:02:45
 Re: 1801 Ford Industrial power steering in reply to Doug Ellis, 05-22-2002 18:14:05
Doug, it is a long story, but through a friend of a friend, I recently became the surprised owner of a 1801 Ford with loader and backhoe. Just like your tractor, it had a faulty power steering cable beyond any hope of repair. I built a hydrostatic steering unit to replace the cable system. Doing that required that I replace the original steering wheel and alter the steering column. With a modification kit, I was able to use the original steering cylinder and power steering pump. The steering looks factory and it works very well. If you would like, I can send you pictures.
Scott
05-22-2002 18:22:49
Your New Holland dealer can order the cables.
