Adjusting the 3pt Hydrolics on Ford 631
Alex F
05-23-2002 09:45:03
i was having a problem with the lift on my 631 - my dads 9N would rasie and implement much higher than mine. So i palyed around with the lever and found that the shaft "slide" in & out a bit. Something i did got it so the 3pt would lift higher, as i suppose it should. Worked well for a couple of days and now it is back to barely lifting the box off the ground.
Any ideas on what i did and how can i do it again?
or - what can i do to fix the lift so it is correct.
Thanks all
