'64 2000 w/loader
need counter weight
Ken Goth (MO)
01-29-2001 10:40:55
I have a 2000 with a Kelley loader on it. I would like to make a counter weight for the three point out of concrete. What would be a good weight and how much concrete (cu. yards)would it take? My idea is to weld a 3 pt frame then put a form around it to cast the concrete. Any opinions/advice?
Cliff
01-30-2001 06:16:58
 Re: '64 2000 w/loader - need counter weight in reply to Ken Goth (MO), 01-29-2001 10:40:55
FYI, Concrete weighs approx. 4000 lbs. per cubic yard, 148 lbs. per cubic foot or nearly 20 lbs per gallon.
RICKWI
01-29-2001 15:40:07
If you hang it on the three point, you loose half the tractor. If you load the tires and add wheel weights, you can still put a blade or other implement on the back. Bone yards usually have used weights.
charlie
01-29-2001 14:01:19
get a 55 gallon drum,cut the top third off,put a draw bar thru it,and fill it up.i can't tell you how much it weights but it holds my 601 down.in the winter it makes good weight in a pickup too.good luck
