Need help with engine cast code # 310609
640
05-24-2002 10:33:29
I have a 1955 640 serial # 76847. I believe that the engine has been swapped out on it. Trying to get parts "carb" , but the ones that I get for the 640 1955 will not bolt up to the intake. the 640 should have a 134 cid engine i believe. All the web site that have looked at tell me the block should have EAE or EAF cast under the dipstick. my engine has 310609. My carb does not have a tsx # on it. Is there any other way to I.D. my M.S carb. It seems to be a much larger carb than the one the dealer has for the 1955 640 134 engine. The block also has casting # 89 M 2 on the left side front by the oil rail. Is this the production code?
