Order Ford 3000 Parts Online
3000 rear weights
Kee
05-24-2002 20:21:01
Bought 3000 a while back. I was cleaning out barn later and seen some pie shaped wheel weights. But I can't remember exactly what they look like. I'm gonna be going back and I need to know what to look for. Any help would be appreciated. Also, the wheels on the 3000 only has 3 holes about 3/4" in dia. How would they hold on if they are the right ones?
Kee
06-02-2002 19:54:04
 Re: 3000 rear weights in reply to Kee, 05-24-2002 20:21:01
Thanks folks for the info. I went back down there & they were not the right ones. They were pie shaped pretty much, about three & half or four inchs thick, app. 8 inchs wide, also two different shapes.. I don't know what they fit. I didn't get them yet but I may later... thanks again... Kee
Festus
05-24-2002 23:48:14
There's also a big round steel plate that bolts onto the wheel first. The pie weights then hook over the edge of that plate then bolt in the center. I don't have any pics of the plate but here's a link to some pics of the pie weights on a 3000. Hope this helps. Good Luck
RICKWI
05-25-2002 08:30:09
 Re: Re: 3000 rear weights in reply to Festus, 05-24-2002 23:48:14
There should be a set of hex nuts with a threaded end sticking out. You remove your lugnuts and replace them with these nuts, then the cast iron disc is held on to these with your lug nuts.
