3 POINT OPPERATION
BOB
05-25-2002 15:13:01
MY 3 POINT HITCH OPPERATES AT ABOUT THE LAST TWO INCHES OF THE QUADRENT TO THE TOP WHAT DOES IT NEED OR IS THIS WHERE ITS SUPPOSED TO OPERATE BY THE WAY IT IS ON A 640 MODEL THANK YOU
DonP
05-27-2002 21:32:03
 Re: 3 POINT OPPERATION in reply to BOB, 05-25-2002 15:13:01
Yes, taking it out of draft control may help. I was just reminded that I posted your same question two years ago, and it helped me. -but behavior was still not quite right, so today I pulled the lift cover off to look into adjusting the lift mechanism. I found I can't adjust it just yet, as I need to replace the cam-follower pin. I'll be contacting Zane asap, it seems he has the adjustment process all documented, based on this post:
Larry NCKS
05-26-2002 09:28:55
TAKE IT OUT OF DRAFT CONTROL!!!!! !!!! Dang! This shouting is hard to read!!!!! !
