Order Ford 2000 Parts Online
1964 Ford 2000
Dave Hickerson
05-28-2002 12:33:52
After stopping my 1964 Ford 2000 for fuel, I tried to restart and got no response from the starter switch. Battery is fully charged, ingition switch is new as is the starter selnoid. Power light on dash lights up whe the key is on but nothing when you depress the starter switch.Help! Any Suggestions!
Dave
John
05-28-2002 20:51:53
 Re: 1964 Ford 2000 in reply to Dave Hickerson, 05-28-2002 12:33:52
Dave, Hold the starter button in and wiggle the shifter. I have a 1963 ford 2000 and sometimes it is tempermental about starting.
LarryNCKS
05-28-2002 16:41:44
Sounds like dirty battery connection if it turns gen light out when u press starter switch.
Dave
05-28-2002 13:38:55
Dave,
Is there any sort of safety interlock? Sometimes those will hang up, sometimes the selonid will also, even if fairly new, I tap mine with my pocket knife (even though the hijacking dangers are outragous) and it kicks over. Learned that on a 50 Ford many years back and it still works today. Good luck.
Mike
Dan Robertson (PIC)
05-28-2002 21:26:18
 Re: Re: 1964 Ford 2000 in reply to Dave, 05-28-2002 13:38:55
third party image
Dave, my 861 did the same thing the other day. Could find no problem until I loosened and slid back the band that covers the brushes on the starter. Brushes looked pretty good, but I did note that the communtator was looking as it needed some service. I rolled the armature (the part that turns) ever so slightly, tried the starter button again, and she fired right up. I haven't done it yet, but I know the starter needs to be taken off and cleaned/dressed up. Just need more time. Dan Robertson
