Order Ford 600 Parts Online
Is a 600 or 800 series tractor like this Massey?
back40
05-31-2002 04:57:51
I recently went and looked at a Massey 231s w/loader. 42 pto hp, live pto, power steering, Perkins diesel, 2wd, differential lock, foot pedal accelerator. I'm used to older Fords (960 and 8n) so a couple of things surprised me. First, it had two levers for the 3 point and even the dealer couldn't explain convincingly how they worked. One labeled position control and the other draft control, both side by side same distance of allowable travel. Having Fords, I'm used to either being "in" draft control mode or not, but this tractor's draft lever seemed to act just as a limit to the position control lever. Does that sound right? The biggest thing was the loader, there was a valve under the seat that allowed fluid to the loader but not the 3pt and vice versa. So you coud run one but not the other unless you turned the valve under the seat. I don't have my old loader installed on my 960 anymore but I could've swore that you could raise/lower the loader while mowing with a rotary cutter. I was looking for a good 860 or 861 w/loader but after seeing this new tractor now I'm wondering if the old Fords are the same way or not. Can you run a loader and 3pt at the same time?
DAVE M
05-31-2002 19:20:49
 Re: Is a 600 or 800 series tractor like this Massey? in reply to back40, 05-31-2002 04:57:51
The 231s MF is almost the same tractor as a MF135
from about 1965-1975. If you know someone who has
a old MF 135,150. ask them about it. A buddy at work has a MF150 and to get oil to pump to the rear scv
you have to put the lever in "CONSTANT PUMP MODE".
Kind of odd, but MF has sold it well for years.
