Ford 535 backhoe
atmsoft
05-31-2002 08:34:38
What cause a backhoe to travel fordward for 30 minuites then stop moving forward at all until it sits for 2 hours?
RickB.
06-01-2002 16:49:48
 Re: Ford 535 backhoe in reply to atmsoft, 05-31-2002 08:34:38
Tired transmission pump or clutch pack piston seals. Does just forward go out, or both F and R? Both would indicate pump; F or R alone would indicate the clutch pack. Also could be the torque converter. A typical overhaul would include rear main engine seal, frost plugs on rear of block & head, flex plate, torque converter, pump as needed, clutch pack seals and drive discs as needed.
