Order Ford 800 Parts Online
Ford 800 No power under load...black Smoke Backfires
Bob
06-01-2002 18:11:16
Under heavy load. New every thing electrical..carburator is worn out from adjustment can't seem to get it to run like it used to! Suggestions are welcome..
Ed in FL
06-03-2002 16:43:21
 Re: Ford 800 No power under load...black Smoke Backfires in reply to Bob , 06-01-2002 18:11:16
Black smoke points to fuel. Is the float level correct and does the needle valve shut off fuel like it should. This realy sounds like a fuel problem.
Ed
casey
06-02-2002 19:15:12
carb!!! carb!!! carb!!! your carb is running to rich thats why it putt black smoke under a load. rpm changes when there a slight load on the machine. but when the buterfly is at certain postiion that dosnt mean that the engine is gona stay at the same rpm position as iot would with out a load. Example: If you butterfly is WIDE open with no load and runningm 2400 rpm, and then your butterfly is STILL WIDE OPEN under a load, the its dumping thwe same amount of fuel but now runnnign more like 2150 or 2200 compared to 2400. So the engine starts to flood becasue when its rich it dossnt ahve the proper amount of oxygen and has too much FUEL! back out on your idle AIR screw a hair at a time and see how that works.
Bob
06-03-2002 02:58:56
 Re: Re: Ford 800 No power under load...black Smoke Backfires in reply to casey, 06-02-2002 19:15:12
My idle air screw seems to have no effect on performance...I can close it and the engine still runs..no roll as the carb ajustment calls for? Any ideas...
Hap
Fighting suburbia in NC
06-04-2002 05:15:43
 Re: Re: Re: Ford 800 No power under load...black Smoke Backfires in reply to Bob , 06-03-2002 02:58:56
If the idle air screw doesn't effect the rpm then there is too much fuel getting by somewhere. Most likely culprit is the float level being set too high. If you run the idle air screw all of the way in it should choke the motor down - applying a little choke at the same time will keep the motor running but only under no load. If it doesn't do this then there is fuel getting by where it shouldn't. Hope this helps.
jwb
06-02-2002 16:20:48
I would check the timing gear the one on the cam. the center hub would slip a little and put the tractor out of time . jwb
D. R. White MN
06-02-2002 11:36:58
Bob, I would check the spark advance in the base of the dist. it my be stuck. Hope this helps. Dave.
REM
06-02-2002 14:30:43
 Re: Re: Ford 800 No power under load...black Smoke Backfires in reply to D. R. White MN, 06-02-2002 11:36:58
I'd check the gap on the points. I think it should be .025. I've seen the points set wrong act very similar. Also if the dist shaft is loose enough the point setting may not be the same when it's running as when it's not.
Check the simple stuff first! REM
