Order Ford 3000 Parts Online
3000 sos input shaft
Brad/WA
06-02-2002 09:03:33
I have split this tractor between trans. & engine. the splines on input shaft and on the drive from engine are shot.Do I have to split it at the rear also to remove & replace input shaft? And how do I replace the drive from the engine?
D Thomas
06-04-2002 13:53:26
 Re: 3000 sos input shaft in reply to Brad/WA, 06-02-2002 09:03:33
I have done this without turning the rear end up. It can be done by holding all parts in place with tension while installing the new shaft, but the other method is probably easier if you can do it.
I had the older (small) spline system on my tractor but I bought the new (larger) splined clutch and had the shaft welded and machined to the larger spline system. It has worked well for 5 years.
Scott
06-02-2002 12:20:40
You lift the trans. straight up while the axles rotate and tires stay still, if you have safe equipment to do it. with the front cover off you can pull the shaft out without the thrust washer falling out of place inside and put the new on in. the drive is a disc inside the flywheel, lust unbolt the presure plate.
