Order Ford 861 Parts Online
Adding power steering to a 861
back40
06-04-2002 05:25:42
Found an 861 with a loader but doesn't have power steering. How hard would it be to add power steering and roughly how much would it cost?
kb ....... I've seen add on power assisted steering from....
06-06-2002 17:01:58
 Re: Adding power steering to a 861 in reply to back40, 06-04-2002 05:25:42
the Tractor Barn in their catalog for $1225. Their website is www.tractorbarn.com.
Hal/WA
06-04-2002 21:17:24
I was under the impression that the Jackson Power Steering would only work with a front loader pump. Has anyone done an installation using a belt driven pump?
jake
06-05-2002 09:34:38
 Re: Re: Adding power steering to a 861 in reply to Hal/WA, 06-04-2002 21:17:24
A belt driven pump will work, the pump would be resticted to the required flow required by the Char-Lynn steering valve. The jackson unit uses the 211-1012 valve requiring 4-8 GPM input, output 14.1 in/3/per rev, also this valve with jackson cylinders will turn full left to full right with 1 turn of the steering wheel. I have done research on this as I am installing power steerin on My Oliver super 55/w loader, the steering gear boxes both use the saginaw recirculating ball systems. Hope this helps
jake
06-04-2002 21:06:50
I helped a friend install a jackson unit on an 8N with the biggest pipe loader I've seen and it is amazing. The hi pressure from the pump is divided with 7 GPM going directly to steering and excess to return manifold. The remainder of hi press goes to the loader valve then to the return. The use of quick disconnect at the controls would permit the removal of bucket and upper arms. As long as the front pump and reservior tank there would be no problem. The cost of the unit is about $1300.00 but is removable as no alterations are made to the tractor. Go to www.jacksonpowersteering.com and view the video you will be impressed.
Van(WA)
06-04-2002 06:49:50
back40, The PS unit does not have any thing to do with a loader, it is a separate unit.
back40
06-04-2002 05:48:48
Just saw the Jackson Power steering info. Looks like it's only available on tractors with loaders and if you remove your loader you lose the PS. I'll keep looking.
Ron-IN
06-04-2002 10:12:15
 Re: Re: Adding power steering to a 861 in reply to back40, 06-04-2002 05:48:48
You could add the Jackson unit and then install a belt driven pump to the engine. I think that Jackson even offers a pump to do just that. Ron-IN
