Testing Hydrualic Pressure
Allan
06-06-2002 06:05:46
Correct me if I am wrong, please. Pressure produced by a loader hydraulic pump (front mount) determines lifting capacity (weight) and pump volume determines speed of action. If that is true how do I determine both the volume and the pressure on a hydraulic system that is currently part of the loader hooked to my tractor? Lift capacity seems a little weak to me. Really appreciate the help.
Fessman
06-08-2002 18:52:06
 Re: Testing Hydrualic Pressure in reply to Allan, 06-06-2002 06:05:46
Allen,
I put a pressure gauge on my loader to get a better understanding of it's load capacity. It cost about $10.00 plus the cost of a few fittings. It was money well spent. It gives me an understanding of where the load capacity / limit is. Buy one.
Fessman
TomG
06-07-2002 02:05:36
Pressure/flow gauges can be found around $200 - $300. Northern Tool may have one. Pressure gauges themselves are around $10 not including fittings and hoses.
One comment: A easy way to think about hydraulics is that pumps produce flow but loads produce pressure. Only enough pressure to move a load is developed. Pumps also don't have 100% volumetric efficiency. The volume pumped decreases as pressure increases.
An approach other than measuring is simply to run the curl to the end of its travel and listen for the pressure relief valve to open. If it opens, then there's not a pressure problem unless the relief valve is low. Pressure tests often are taken to adjust relief valves.
Generally a pump that can open its relief valve doesn't have too bad a flow. However, obstructed suction lines and clogged filters will reduce flow.
Allan
06-07-2002 08:35:14
 Re: Re: Testing Hydrualic Pressure in reply to TomG, 06-07-2002 02:05:36
Tom G,
Thanks. If I may dig a bit deeper - if the loader won't lift as much as it should or even close, then the pump is not producing the pressure because it is worn out, the relief valve is set too low or not working properly, or the lines / fittings are not allowing pressured fluid to pass to cylinders? I have a Vickers Vanepump Model 16 on my tractor for the loader. Loader is a 19-105 and tractor is an 841. What kind of load can I expect to lift? I am hearing outfits similar to mine lifting 1000 - 2000 pounds and the limiting factor being the front end of the tractor bearing the weight and the rearend coming off the ground. I am not familar with these pumps and any tests to see if things are working properly would be recommended. One more thing - is there a relationship between load weight and pressure required to lift it? Physics here we come. Thanks so much.
TomG
06-08-2002 03:46:43
 Re: Re: Re: Testing Hydrualic Pressure in reply to Allan, 06-07-2002 08:35:14
Alan: I can't be much help with what is normal for the tractor or loader. 1 - 2 K doesn't sound too unrealistic, but comparisons with other 841's should be with the same loader. Loader frame geometry and cylinder diameters affect how much can be lifted. Condition of the hydraulic system also affects load limits. The pump is only one element of the system. The loader cylinders, control valves, oil condition and screens and filters are other elements.
Checking the general condition of the system would be good. Condition of filters and screen should be known and the oil should not become abnormally hot or frothy during normal work. A diverter valve (if present) should be fully in the auxiliary system position. The loader should not leak-down under load.
If the general system checks out, a relief valve pressure test will test for pump/relief valve condition. A manual would describe the procedure. If pressure tests low, the pump may be worn but the relief valve may be faulty. Most relief valves are adjusted by placing shims behind a spring. If adding shims doesn't bring up the pressure, the pump likely is at fault.
In terms of theory, a relief valve test can be thought of as applying an infinite load to the system to force the relief valve open. A system never has more pressure than is required to move a load. Oil is pumped continuously in an open centred system, and line pressures are around 100 lbs. when noting is operated. The 100 lbs. is the load of the lines and apertures. Lifting anything requires increased pressure and pressure is the only thing that moves a load. Heavy loads develop more pressure than light ones.
Pumps are often thought of in terms of their ability to withstand, rather than to develop pressure. Vane pumps typically wear well but fail catastrophically. The performance gear pumps typically declines gradually over their service lives. However, all type pumps in acceptable condition should be capable of withstanding pressures quite a bit higher than the relief valve pressure (which limits the maximum load in a system). If a vane pump is pumping at all, it’s fairly likely that it would be capable of opening a properly adjusted relief valve unless there were many hours on the pump.
