Order Ford 2000 Parts Online
2000 won't run on alternator alone
Mark Paden
06-09-2002 04:20:13
My '63 2000 used to run on the alternator alone (once started, you could disconnect the batt. cable and it would keep running). Now it doesn't, and a new alternator (3 wire 10si, putting out 14 1/2 volts) didn't help. Any ideas?
Jim WI
06-10-2002 10:58:16
 Re: 2000 won't run on alternator alone in reply to Mark Paden, 06-09-2002 04:20:13
Yep -- that test is no good. Some sources even say that you can damage the alternator testing it this way.
Does the alternator keep the battery charged? If so, don't worry about it.
