Hydraulic problems
Aaron
06-09-2002 10:03:32
I have a 961 and I lost my hydraulics to the loader and 3 point. I found that the gear in the pump let go so I had it rebuilt at the dealer. I put the pump back on and still have no hydraulics. Do I need to bleed the system or prime the pump ? What else could it be.
Randy
06-10-2002 05:25:58
 Re: hydraulic problems in reply to Aaron, 06-09-2002 10:03:32
Had a similar problem on my 901 Ford when I first rebuilt the pump. I took the pump back off and filled it with fluid and after reinstalling it it worked fine.
Scott
06-09-2002 12:32:45
Yes, you must bleed the air out at the allen head plug on the front top of the pump.
FPA
06-09-2002 11:24:29
Don't know your system, but logic says check the level of hyd fluid first, then check the relief valve...something could be stuck in it causing flow to go to tank.
