Order Ford 800 Parts Online
800 hydralic pump question
Bill from MO
06-13-2002 22:52:51
Is there away to remove the ball valve seats in the pump assembley with out the special tool? Is the special tool (#NCA-600-G) still availabe? Does anyone have one to sell? Any help would be appreciated. Thanks, Bill
Richard C. Rose
06-14-2002 02:42:19
 Re: 800 hydralic pump question in reply to Bill from MO, 06-13-2002 22:52:51
Gidday Bill,
I believe you should be able to tap the seats out to 5/16" unc, then by winding in a long threaded bolt (with a nut wound right up it), through an appropriate size socket you should be able to draw the seat up into the socket.
I have definitely had success this way, it is only the model I'm not 100% sure of.
Good luck Richard
Bill from MO
06-15-2002 09:37:41
 Re: Re: 800 hydralic pump question in reply to Richard C. Rose, 06-14-2002 02:42:19
Richard,
Thanks for the info. I hadn't thought of that. I'm going to try it! Bill
