Hey Ford guys
need help
BIG JOHN
06-16-2002 04:14:29
In the process of redoing a 641, started to remove paint off headlights and the bezels that hold the light in have alot of holes, can you buy these or can you still get new factory lights?
does anyone make correct repo's.
Got new waterpump from dealer has 4 bolt for fan- mine has 6 rivets holding pulley and fan, the casting looks right, do you press the hubs off somehow? switch? or does dealer have complete?
BIG JOHN
Scott
06-16-2002 10:29:21
 Re: Hey Ford guys - need help in reply to BIG JOHN, 06-16-2002 04:14:29
Yes, New Holland still sells the original headlights part# 310066F (6 Volt), or just the retaining ring part# C0NN13045B. The parts man must be new, he should have asked you if your water pump was changed since 1971, Ford updated the pump back then and now uses a bolt on spacer, 4 blade bolt on fan and bolt on pulley.
Pete
06-16-2002 05:15:20
Big John; I have a set of original lights that came off a Ford 630 they are in excellent shape,6 volt and they work email me if you are interested
