Order Ford 2000 Parts Online
2000 carb problem
Robert
06-18-2002 12:24:20
The carb in my Ford 2000 was just rebuilt the problem is during acceleration from idle there seams to be a flat spot,a miss of some sort.The carb had been rechecked and all seams to be fine. Before anyone asks yes the timing and settings were all checked. This is my first tractor so I don't know if this normal or not if it is' it's not good. Can anyone help thanks.
Mike
06-18-2002 14:18:32
 Re: 2000 carb problem in reply to Robert, 06-18-2002 12:24:20
If your 2000 is a 3 cylinder, you will always have a "flat spot" when you accelerate. All the 3 Cyl Fords did that. A 4 cycle engine with only 3 cylinders is going to have a "dead spot" where nothing is firing. When you accelerate or let the clutch out, it gives the apprearance of a flat spot. When the engine is pulling hard or when you are going downhill, the engine may appear to lope a little. This is also due to only having three cylinders. As long as everything is set properly, timing and carb, you should have no problems. If you have any other questions, drop me a line.
