2,4-D Amine 4
Charles W. Stor
06-19-2002 18:26:23
I know this is totally off base.
I have 5 gallons of weed killer(2,4-D Amine 4), does anyone know the mixing ratio per gallon for general weed killing.
guy
07-03-2002 17:30:33
 Re: 2,4-D Amine 4 in reply to Charles W. Story, 06-19-2002 18:26:23
1 pint/acre in early spring--1-2 quarts in summer-- with less results then in early spring
David C. Baker
06-21-2002 10:38:51
Tim's 40:1 mix is about right. I'd say 1--1.5 gal per barrel (55 gal). But watch it: the amine formulation is the volatile kind, and the summer's heat can spread it around.
TimK
06-20-2002 07:35:15
I use a sprayer for the yard pulled behind the garden tractor. I use 40:1 mix and as long as I keep the tractor moving, it works well.
