Order Ford 800 Parts Online
1956 Ford 800, No Crank
Chuck Barrow
06-23-2002 09:28:27
I cant get my tractor to crank,it was converted to a 12 volt system a few years ago. So far I've replaced the battery, soleniod, cables and starter brushes. All connections are tight and the battery voltage is 12.75. I've tried jumping the soleniod and then connecting directly to the starter. All I get is a cluck from the starter. Does anybody have any suggestions.
tlak
06-23-2002 12:22:05
 Re: 1956 Ford 800, No Crank in reply to Chuck Barrow, 06-23-2002 09:28:27
You about got it narrowed down. If your jumping strait to the starter you either have starter problems or something locked up on the engine. You can pull the starter and jump hot to the post and ground to the case and see if it turns. You could pull your tractor and see if it turns over all right. If your 12V conversion worked up till now then you have to go back through it to find out whats wrong. Maybe a low battery.
