Order Ford 601 Parts Online
1963 Ford Tractor 601 Workmaster
Bob
06-23-2002 10:06:07
I have a 1963 Ford Workmaster 601 and would like to run a small irrigation pump off the pto. I need to know what the ratio is from the engine rpm to the pto.
Thanks, Bob H.
George H
06-23-2002 22:43:58
 Re: 1963 Ford Tractor 601 Workmaster in reply to Bob, 06-23-2002 10:06:07
With 4-speed transmission, 540 pto speed is at 1485 engine rpm, or 2.75-to-1. With 5-speed or SOS, 540 pto speed is at 1750 engine rpm, or 3.24-to-1.
Bob
06-24-2002 15:29:25
 Re: Re: 1963 Ford Tractor 601 Workmaster in reply to George H, 06-23-2002 22:43:58
Thank you George. Any ideas on how to get it up to 3450 rmp pto?
Bob H
06-25-2002 17:07:42
 Re: Re: Re: 1963 Ford Tractor 601 Workmaster in reply to Bob, 06-24-2002 15:29:25
Thank you Greg and J Hill for your information.
Greg
06-25-2002 12:36:38
Bob, There is a PTO driveline in the Northern Tool & Equipment Company catalog #969 on page 301. It is item #165946-B969. It is rated 109 HP and is for use with a generator, which probably runs at about the speed you're looking for. Also try northerntool.com.
JHill
06-25-2002 08:41:49
Turbine type sprayer pumps for farm use have to turn at faster than PTO speed to work properly. They use 2 pulleys and a belt to do this. You should be able to do this also. Look at TSC or a farm store
George H
06-24-2002 21:19:32
No good ideas at all, but I'm not too familiar with farm implements. I'm sure it's been done. The only pto gearboxes I've seen are 1:1 or gear reducers. Homemade, I'd make a 3-point frame to mount the pump and speed it up with pulleys and belts.
