Order Ford 3000 Parts Online
1973 Ford 3000, 2 stage clutch
Sam MI
06-30-2002 09:12:01
Looking for advice on after market pressure plate assy. and clutch disc. for my tractor. Appears that non OEM units are cheaper than FNH. Wondering about quality. Any coments appreciated. Thanks
Mark K.
06-30-2002 21:53:16
 Re: 1973 Ford 3000, 2 stage clutch in reply to Sam MI, 06-30-2002 09:12:01
Hello, I have a Ford 4000 72 model and had a throw out bearing lock up "without noise how I don't know" and it wore the fingers off the pressure plate. FNH was very high on price so I went to a clutch rebuilder that ordered a new one. That’s fine but the springs are very strong and I think my right leg is 2 inches larger than the left. If mine could have been rebuilt it would have been fine but... If they have to order you a new one have them check the spring tension. Mark K
Ed in Fl
06-30-2002 16:36:04
Probably the best option would be to have your clutch rebuilt. Most cities have a company that rebuilds clutch pressure plates and disks. Ask specifically if they have the tools to rebiuld and set up one of these clutches. I had mine done that way and the dual stage pressure plate and both clutches and the clutch alignment tool wound up costing $210.00. Ed
Sam MI
07-01-2002 06:27:13
 Re: Re: 1973 Ford 3000, 2 stage clutch in reply to Ed in Fl, 06-30-2002 16:36:04
Hi Ed; Talked to my NAPA guy. He say's he can send it to Milwaukee and have it rebuilt. where did you get the clutch alignment tool? Last clutch I replaced was on a Ford flathead. Still got that tool.
Rick.
06-30-2002 10:56:25
We sell Hy-Capacity at work. Parts quality is good, but we have learned to put each double clutch assembly on the jig & set the finger height and PTO plate linkage. Still, it's very affordable compared to OEM. We have also had good luck with clutches from A&I, though we haven't tried that particular clutch from them.
