1953 Jub 134 CID Blook question.
Mark Hendershot
07-01-2002 21:37:59
Can the engine block out of a 53 Golden Jubilee fit into other ford Tractors like the NAA 600 or 601 ect?? Some seem to use a 134 Engine too. I had one to sell and was not sure if it could be used in other tractors also. Thanks, Mark H.
Phil (VA)
07-02-2002 06:38:54
 Re: 1953 Jub 134 CID Blook question. in reply to Mark Hendershot, 07-01-2002 21:37:59
The Jubilee and the NAA are essentially the same tractor, just one has the golden emblem and the other has regular emblem. Later version had better hydraulic pump. Engine is same. Also, this is the same 134 c.i. "Red Tiger" engine as used in the 600, so the short answer to your question is "yes."
Mark Hendershot
07-02-2002 08:31:01
 Re: Re: 1953 Jub 134 CID Blook question. in reply to Phil (VA), 07-02-2002 06:38:54
Thanks that helps! Mark H.
