961 hydraulics
brad finke
07-02-2002 19:54:18
anybody have the info i need to get hydraulics on this tractor
DonP
07-05-2002 06:44:27
 Re: 961 hydraulics in reply to brad finke, 07-02-2002 19:54:18
Paul is correct, we do need a little more info, but if you find that you don't have any auxilliary/remote valve at all, contact Zane Sherman. He has instructions on how to modify/plumb the adapter plate to add remote hydraulics.
-Reason you may not already have a remote valve: The guy that bought the tractor new may not have wanted that option, the valves were options, not factory-equipped defaults.
-Reason you may not want to get a "ford-original" valve: It may cost you $200-400, you can get an after-market valve for around $100.
-How to tell if you have a aux. valve at all: Look under the seat, just inside the 3-point touch-control quadrant. If you find a flat, approx 4 x 6-inch flat plate, you have no remote valve at all. If you find another handle, you have a valve, and just have to figure out if it is single or double-spool and how to use it.
If you decide to contact Zane, his e-mail is wzsherman@aol.com, or search the archives for a link to his web-site, where you will find his phone number.
Have a good-un.
DonP
paul
07-02-2002 21:48:48
The _6_ series should have come with hydraulics???? so, I'm not sure what you are asking for? Sorry.
--->Paul
brad finke
07-03-2002 05:46:37
 Re: Re: 961 hydraulics in reply to paul, 07-02-2002 21:48:48
i would like to use a hydraulic log splitter or attach a loader some day the single line hyd is not sufficent thanks brad
paul
07-04-2002 22:16:49
 Re: Re: Re: 961 hydraulics in reply to brad finke, 07-03-2002 05:46:37
For a loader you might want a front-mount specialty pump.....
For other stuff, first you need to tell us what you do have. Up above is a good thread with pictures does yours look anything like those? Some only need an adaptor plate stuck in - some only need the other hose connected & the thumbscrew turned in... Some need a lot.
What do you have exactly to start with? Probably need a picture for others to identify??? Which pump do you have, vane or piston?
(By the way, I don't know much about it, I have a 960 with double-acting, vane pump. Just hoping my comments will draw more discussion to help you. :)
--->Paul
