Polarity of coil?????????????????
BIG JOHN
07-05-2002 03:48:56
Which side or terminal goes to the distributer the positive or negative, tractor has 6volt positive ground. old coil said 'dist' and 'batt'
this new one has + and -.....
thanks
John in WI
MarkB
07-05-2002 19:04:05
 Re: polarity of coil????????????????? in reply to BIG JOHN, 07-05-2002 03:48:56
The reason the new one says "+" & "-" is that it could be used on either a positive or negative ground system.
Since the coil grounds through the points, you would hook "+" to the distributor on your positive ground system.
Jerry D in NC
07-05-2002 04:09:54
The + would go to the distributor and the - battery.
