I know, another hydraulic question! But here goes! I have a '64 model 4 cylinder 2000 with a Freeman manure loader attached. I have used it for about six years now but recently it took about 2-3 minutes of running to "build pressure" and the lift to work. I thought maybe it was loosing prime.I inhereited my dad's 35 Ferguson and was using it for the last 6 month or so. When I went back to use the Ford with loader the lift wouldn't work at all. I tried the lift spool valve in both positions and pulled the plugon the side of the piston pump and it was moving fluid. The fluid level is ok. I am leaning towards the relief valve. Do you guys have any idea's. I am about to tear it down, but if there is a quick fix it would be greatly appreciated. Before this, the lift and loader were very strong, lifting the tractor of the ground when I pulled out some trees from the fence row. Thanks for any help. By the way, the 35 Ferguson now has a wacky hydraulics as well, but that is anothe story! It involves the draft lever. Thanks again.
