Order Ford 640 Parts Online
640 power lift//HELP
Ben.So.Tex
07-08-2002 15:04:10
I used my 640 yesterday to bush hog about 3 arce of small grass and it work fine, when I finished I put it in the shed. About one hour later My nephew wanted to borrow it to drill two post holes, I started it up and when I went to raise the power lift it would not raise,,But when I increase the RPMs about 3/4 speed it would raise,,Oil is fine What could be the problem,,Ben
Greg
07-25-2002 17:21:46
 Re: 640 power lift//HELP in reply to Ben.So.Tex, 07-08-2002 15:04:10
Ben, I have a 640 with a similar problem only it is bothersome in cold weather only. I suspect you have the vane type hydraulic pump. A changeover to the piston type or pump rebuild of the vane will probably solve the problem. First, check to be sure your rear axle oil levels and hydraulic oil are full and in good shape (not discolored, signs of water, etc). You may have air in the system but I'm not sure how to bleed it off.
