Mr. Benjamin, I don't believe the C086 is a model number; you should find a model number something like 31013B; 1st Digit:'65 - '67: 2= 2000, 3= 3000, 4 =4000 etc ----- ----'68 on: B = 200, C= 3000, D= 4000 etc. 2nd two digits:- 10 straddle mount agricultural ----- ----- ---- 20 row crop, flat deck ----- ----- ---- 40 Utility, light industrial ----- ----- ---- 50 Industrial 3rd digit:- 1 diesel ----- ---- 2 gasoline 4th digit: 2 manual shift PTO ----- --- 3 Double clutch PTO ----- --- 4 indepentent PTO ----- --- 5 indepentent 2 spd pto 5th digit(letter): B= 6 speed, C= 8 speed, E = 10 speed, F= 4 speed power reversing. ----- - not a complete list - ----- -- Model should be stamped on top transmission just behind the starter above the implement mounting pad or same place on LH side. It also should have been stamped on the aluminum decal plate under the hood above the battery. In spite of assembly in Antwerp, it has essentially the same power train as one assemble in the US. Differences are inset headlamps, full skirt or flat top fenders, wider step plates, different wiring harness for turn signals, hi-lo beam headlamps.
