3-Point lift wont go up....
Craig
07-11-2002 12:25:07
LIFT WONT GO UP. Having a problem with my 850 Ford tractors 3 point lift. Tryed to bleed out the air buy taking out the set screw. There was some fluid coming out of one srew (plug), but nothing out the rear plug. (on the pump).Any suggestions?Orrioginal owner rebiult the pump(piston type)and I changed all the fluids.It also has a valve for the loader under the seat. Thanks , Craig
ZANE
07-14-2002 18:13:26
 Re: 3-Point lift wont go up.... in reply to Craig, 07-11-2002 12:25:07
You should never remove the rear plug in the pump except to add a little oil when first installing the pump after it has been drained for any reason. Even then it is not usually necessary to remove the rear plug to bleed the pump.
Removing the rear plug is a big mistake if you are trying to bleed the pump. The rear section is the suction section and when you remove the rear plug and run the tractor you are filling the pump with air and this pump will absolutely not pump any air. If this pump has a pet cock or similar fitting on the suction side of the pump you should remove it and replace it with a pipe plug wrapped with teflon tape to assure it does not allow air to enter the pump.
Remove the front plug only and allow the engine to idle until you can detect no air bubbles coming out with the oil. When there is solid oil coming out of the pump, stop the engine and replace the plug. If the lift still will not raise then you got other problems such as a stuck unloading valve in the body of the lift housing.
Craig
07-13-2002 19:51:30
I tried letting it run for 20 minutes or more bleeding the air out of the pump.The pump has a bleeder in the front and one a lttle ways back.I tried bleeding both , the front has some air bubbles and fluid comming out of it , but I can take the rear bleeder(twards the back of the tractor)completly out of the pump and nothing comes out.Should I try to poor some hydrolic oil in the pump?, then put the plug back in ?IM not sure what to try.Like I said the tractor does have loader levers under the seat, but I have the loader off and the lines caped off.Do I need to bleed the controler ? Thanks for any help Craig
tom
07-11-2002 19:39:47
Will she lift if you let her sit there and run for 5 minutes or so. My 851 has started acting this way and bleeding is of little help.
