730 Hd Loader cylinders
Charles Story
07-16-2002 09:13:41
I am having to replace the bucket and lift cylinders on my Ford 730 HD loader. Ford does not carry these cylinders and I am having to get them from another source. I need the the cylinder bore, stroke and retracted length for these cylinders. All help appreciated.
Justin 3000 NC
07-16-2002 18:00:24
 Re: 730 Hd Loader cylinders in reply to Charles Story, 07-16-2002 09:13:41
I've got a Ford Loader Service Manual that covers 727, 730, 735, and 740 loaders. It states the following for the 730 model...
Lift Cylinder: Retracted Length 42-11/16" (108.43cm) Stroke 33-5/16" (84.61cm) Piston Diameter 2"
Bucket Cylinder: Retracted Length 31-5/16" (79.53cm) Stroke 20-1/16" (50.96cm) Piston Diameter 2"
Apparently that model is available with either a single acting or double acting cylinder setup and depending on which you have the rod diameter will vary (S/A is 2", D/A is 1-1/2"). I didn't see a listing for cylinder bore, but perhaps the diameter measurements given will help.
Let me know if you need any other info from this manual.
Justin
