Order Ford 2000 Parts Online
2000 Brake Drum Removal
Jim in MD
07-18-2002 16:21:51
I'm having a difficult time getting the brake drum off of my 1972 2000. I've loosened the brake shoes, used copious amounts of penetrating oil and pounded on the drum. The local tool rental place does not have a wheel puller large enough to span the drum.
Any ideas?
Gary Miller
07-22-2002 17:17:26
 Re: 2000 Brake Drum Removal in reply to Jim in MD, 07-18-2002 16:21:51
Snap-On-Tools has a puller big enough, I have one.
I have had to put the puller on the drum and tighten it pretty hard. Then put the fire wrench on it also.
Gary
Fighting suburbia in NC
07-19-2002 06:03:43
Like Rick said, heat the drum center around the axle hole. Keep the heat off of the axle center as best you can. After you get the drum hot cool the axle center with a squirt bottle of water and it should loosen right up.
Another trick is to be up on jack stands, get the drums spinning (without tires bolted on) and then slam the brake. This will provide a little shock to the assembly as the axle twists and the drum doesn't and might be enough to get them to break free. Leave a lug nut or two on loose to keep the drum from flying off.
RickB.
07-18-2002 18:28:34
Find a puller large enough to do the job. Heat the drum's pilot hole area with an acetylene torch. Did you back the brake adjuster off?
Jim in MD
07-18-2002 18:43:10
 Re: Re: 2000 Brake Drum Removal in reply to RickB., 07-18-2002 18:28:34
I backed the brake adjuster off right after removing the tire. I'll try to locate a larger puller tomorrow.
