Order Ford 2000 Parts Online
2000 lift problem
Dennis Roberson
07-25-2002 14:54:48
I have really enjoyed lurking here and reading the messages..now I have a question ! I have a '68 2000 that the lift seems to have amind of its own. Sometimes it will raise and sometimes it won't. Any ideas will be appreciated.
Thanks,
Dennis
RIckB.
07-25-2002 16:44:02
 Re: 2000 lift problem in reply to Dennis Roberson, 07-25-2002 14:54:48
My advice on hitch covers is usually the same. It only costs a few bucks more to buy the parts to completely overhaul the average lift cover than to only buy parts for what seems to be wrong. New piston seal and backup, o-rings between the cylinder and lift cover, o-rings for between the lift cover and remote valve or accessory plate. A new cam follower pin and unload valve seal. Lift cover gasket, o-rings for supply and return ports, and a return filter. Adjust internal linkage. Only the most abused and neglected systems need a safety valve or cylinder & piston replacement, or other valve work. Pump overhaul is a separate issue and there is no redundant work if this needs to be done later.
