Identify ford by serial number
Ben
07-31-2002 20:33:28
I was looking at a Ford tractor with a serial number EAE 6015 J. Can anyone tell what model it is and approx. how much is it worth?
Thank's in advance.
Jim.UT
08-01-2002 14:06:37
 Re: Identify ford by serial number in reply to Ben, 07-31-2002 20:33:28
DonP is right. That looks like an engine casting number for a 134 cu in Red Tiger engine. Could be a 600 or could be a 700. Maybe others. Here's a site to help with the location of model and serial numbers.
DonP
08-01-2002 08:53:28
Ben, That looks like an engine id #.
You should find the Model # and Serial # stamped (not cast) into the flat spot on the transmission housing, right where the starter bolts into the tractor. (You may need to scrub off some grease/dirt to see it.)
Would you be able to re-post with those numbers?
DonP
