Ford FORKLIFT
Andy
02-04-2001 21:41:02
this forklift has 172 gas engine,ford chasis
front mount hydraulic pump.Did FORD make these
or just supply parts? Need help on I.D
RICKWI
02-05-2001 09:06:24
 Re: Ford FORKLIFT in reply to Andy, 02-04-2001 21:41:02
Does it say SHERMAN on it anyplace?
Tony Jacobs
02-04-2001 22:25:01
Hi Andy , YES FORD DID BUILD FACTORY FORKLIFTS, Do you have model number, serial number, pictures, front steer, rear steer, tractor sheetmetal, trnasmission type, any guess to what year it may be 50's, 60's, 70's ? Can't I.D. something without information and lots of it. Thanks Tony Jacobs
charlie
02-05-2001 17:00:52
 Re: Re: Ford FORKLIFT in reply to Tony Jacobs , 02-04-2001 22:25:01
warner-swansey built one with ford engine,transmision,and rear end.they where sold by ford dealers.good luck
Gelloyd Bjerke
06-14-2001 12:32:38
 Re: Re: Re: Ford FORKLIFT in reply to charlie, 02-05-2001 17:00:52
We are looking for a shuttle clutch for the ford forklift. any ideas where to look????? ??
Texadian
02-08-2001 20:41:02
Ford Tractor built a model 4000 forklift on the 4-cyl 4000 (801 family), 172 cid engine power train in the early 60's. It has a large cast counterweight integral with the grill.
After 1965 there were a number of manufacturers that built Fork lifts on the 3000, 4000 3-cyl industrial powertrains such as KD, Sellick and as Charlie says, Warner Swasey which was retailed through Ford Tractor dealers. oimnser
Andy
02-13-2001 15:56:11
 Re: Re: Re: Re: Ford FORKLIFT in reply to Texadian, 02-08-2001 20:41:02
I can't find any I.D tag or numbers.It has forward
reverse shuttle.It has white sheet metal and blue
chasis,a huge counterweight,"front hyd pump",
some of the parts are in INDUSTRIAL 800 parts book. It seems to say "marshall" on hood, but its
not real legible.The hood is squared off, not like
a 800.The steer axle is heavy duty i used king pins from FORD truck possibly F-600 they were a
perfect fit.Brakes are in the wheel.
