Order Ford NAA Parts Online
Wagner loader for NAA
ADK dude
08-05-2002 10:35:46
probably foolishly I just gave a guy 75 bucks for a wagner loader, I think its a WM4. Its solid but rusty, has no pump and is missing the front cylinder for the bucket. How can I go about buying the hardware I need (pump ,shaft, cylinder), should I cut my losses and scrap the thing or can I get the parts at a reasonable cost. I want to put it on my 53 jubilee.
Mike in Ohio
08-11-2002 19:16:30
 Re: Wagner loader for NAA in reply to ADK dude, 08-05-2002 10:35:46
Hey dude--
You might call the Surplus Center in Lincoln, Neb.
They have alot of hydraulic stuff and you might find a pump and cylinder that may not be original but it may be workable and affordable. Their toll free number is 800-488-3407. Ask them for a catalog then look for something that will meet your needs. They don't carry parts for a specific application, just surplus parts (new and used) that can often fill a need.
DaveM
08-08-2002 06:33:49
ADK,
I have a wagner loader with all parts also that I took off a 640. I'm located in SE Indiana if your interested.
Thanks,
Dave Mattlin
Jim.UT
08-05-2002 21:45:53
Keep looking for another loader with all the parts you need. I sold one of those loaders with a pump and bucket cylinder still intact for $400 total. Keep the one you have for parts.
geok
08-05-2002 14:14:52
If you lived near OK, I have a wagner that has the front cylinders and pump with it.
Van(WA)
08-05-2002 12:06:39
ADK dude; Depends how much; use/work/play/ you have for the loader. A new pump will cost you $400., maybe more??, plus hyd cylinder, you will end up with $600 or more spent, unless you can buy some used stuff!!There is no Free lunch out there,, luck to you.....
DonP
08-05-2002 11:52:22
The thing to mount the shaft to run the pump, and the shaft for the pump, are availble at your (or at least, at my, FNH dealer.
-things get pricey when you get to the pump, I think. and I hope someone can help with details, because I am in pretty much the same place.
DonP
