Ford 3910
bob
08-11-2002 09:10:43
Anyone tell me please where to look on a 3910 series III for the serial no.? I've been all over it & can't find a tag anywhere.
Joe M
08-12-2002 17:39:36
 Re: ford 3910 in reply to bob, 08-11-2002 09:10:43
If the tags not under the hood above the battery, look on the flat pad just below and to the rear of the starter. The serial number and unit number will be stamped there
Rick Ga.
08-11-2002 09:26:37
Hi Bob. All of the 70's & 80's Fords that I have looked at had the model and serial # stamped into a small data plate on the underside of the hood on the right side where the battery is located. When you raise the hood it should be right in front of you. HTH. Rick GA.
bob
08-12-2002 18:50:57
 Re: Re: ford 3910 in reply to Rick Ga., 08-11-2002 09:26:37
you were rite on! thanks a heap.
