Order Ford 4000 Parts Online
4000 tractor paint
J. D. Hurley
08-11-2002 15:51:18
I have just bought a can of the old style gray from the New Holland dealer. I believe it is for the 8n. Can any one out there tell me the color numbers for the 4000 series in 1962 and 1963.
Glen
08-12-2002 16:42:58
 Re: 4000 tractor paint in reply to J. D. Hurley, 08-11-2002 15:51:18
The paint I was told from ford dealer is blue#9613386DS Gray#M1J-957-SE2DS
Rod MI
08-11-2002 18:55:20
Ford 4000 Blue part#9613385DS Gray Part#M20J1750SE5DS
Scott NO!
08-12-2002 05:09:20
 Re: Re: 4000 tractor paint in reply to Rod MI, 08-11-2002 18:55:20
Rod, M1J1750SE is gray gloss (white) that did not come out until 1965. He should use M1J957SE (gray).
Rod MI
08-11-2002 19:00:18
I took the numbers right from the can and matches my 1962 4000 perfectly and it grate paint but use hardener with it and it will discolor if gas dries on it Rod MI
Scott
08-11-2002 18:25:12
The gray is M1J956SE or M1J957SE I forget, it was used up to 1965.
Bill Hires
08-11-2002 16:29:16
Dupont lists several gray codes for that tractor.
These are L9809, a good match F0619. Check with their Tractor and Implement Color Group at 1-800-338-7668 Dupont Company.
Tractor Blue codes are 7251 AD, Martin Senour cross listing is 1066-also see 55002 AD.
