Order Ford 4000 Parts Online
4000 WHAT YEAR
Rickey-Tn.
08-14-2002 18:39:56
Got the 4000 I had ask about a couple of weeks ago.I want to order a service manual,but I'm not sure of the model.The only numbers I find are on the housing under the seat mount.They are NCA501 4M16: ,any help would be great.Thanks
Bill
08-14-2002 18:58:42
 Re: 4000 WHAT YEAR in reply to Rickey-Tn., 08-14-2002 18:39:56
look on the transmission housing usually just behind the starter for two numbers.. one will be the serial number... is this a 4 cyl or 3 cyl 4000..
Rickey-Tn
08-14-2002 19:14:34
 Re: Re: 4000 WHAT YEAR in reply to Bill, 08-14-2002 18:58:42
Thanks Bill it's a 4 cy. Found the ser # 162751 think its a 63.Had some other #'s just above don't know what they mean looks like 841 or it could be 041 can't tell for sure till i do a little more cleaning.Again thanks.
Jim.UT
08-14-2002 19:50:54
 Re: Re: Re: 4000 WHAT YEAR in reply to Rickey-Tn, 08-14-2002 19:14:34
Sounds like maybe it's a junkyard transmission that was removed from a '62 Ford 841.
Mike Melton
08-14-2002 22:40:08
 Re: Re: Re: Re: 4000 WHAT YEAR in reply to Jim.UT, 08-14-2002 19:50:54
Can either of you gentlemen tell me where to add oil on my 4000. I have looked high and low to find a fill spout but obviously not high or low enough. I find two possibilities in the front of the engine but they look like a power steering unit and something else. Help! Not much of a mechanic.
JohnG
08-15-2002 05:31:25
 Re: Re: Re: Re: Re: 4000 WHAT YEAR in reply to Mike Melton, 08-14-2002 22:40:08
jeezis man i hope theres oil in it?! On the right side of the motor, under the power steering, theres a crankcase vent on the block. Its a breather cap on top of a (2 or 3 inch) diameter pipe. Pull off the breather and add the oil there. On mine the old owner attached a 8 inch radiator hose because of the blow by. Mine is a 62 4000 gas engine. Good luck! If ya need a pic?, let me know.
