Order Ford 4000 Parts Online
1962 ford 4000 propane and sherman trans.
David Tidwell
08-15-2002 20:39:00
Can't find any info on tractor and would like to restore it. It was bought new by my grandfather in Ripley Miss.
Tommy D
08-16-2002 05:41:33
 Re: 1962 ford 4000 propane and sherman trans. in reply to David Tidwell, 08-15-2002 20:39:00
Check this site out => All you should want to know....
Good Luck!
Tommy D.
Link
JohnG
08-16-2002 05:22:26
I never heard of one but im sure they made it. Do ya have a digi camera?, cause i was wonderin if it was and different from my 62 gas 4000? Probly not much different but im just nozy :)
david tidwell
08-16-2002 05:40:10
 Re: Re: 1962 ford 4000 propane and sherman trans. in reply to JohnG, 08-16-2002 05:22:26
It never had a gas tank on it and the tank is mounted on the front. The tractor was not gray it was tan. I have read that the sherman has 3 gear ratios, Ihave only found two. I'll see if I can get some pictures out.
Horseman
08-16-2002 12:27:01
 Re: Re: Re: 1962 ford 4000 propane and sherman trans. in reply to david tidwell, 08-16-2002 05:40:10
The sherman shift patten is like an upside down h.
in the nuetral position pullit out away from tractor case and then up.That would be direct drive. down is low up is high andout and up is direct. Take care WRP
